Support#
All support for BeagleV-Fire design is through BeagleBoard.org community at BeagleBoard.org forum.
Production board boot media#
Certifications and export control#
Export designations#
  • HS: 8471504090
  • US HS: 8543708800
  • EU HS: 8471707000
Size and weight#
  • Bare board dimensions: 86.38*54.61*18.8mm
  • Bare board weight: 45.8g
  • Full package dimensions: 140 x 100 x 40 mm
  • Full package weight: 106g
Additional documentation#
Hardware docs#
For any hardware document like schematic diagram PDF, EDA files, issue tracker, and more you can checkout the BeagleV-Fire design repository.
Software docs#
For BeagleV-Fire specific software projects you can checkout all the BeagleV-Fire project repositories group.
Support forum#
For any additional support you can submit your queries on our forum, https://forum.beagleboard.org/tags/c/beaglev/15/fire
Pictures#
Change History#
Note
This section describes the change history of this document and board. Document changes are not always a result of a board change. A board change will always result in a document change.
Board Changes#
For all changes, see https://git.beagleboard.org/beaglev-fire/beaglev-fire/. Versions released into production are noted below.
Table 106 BeagleV-Fire board change history#
Rev
Changes
Date
By
A
Initial production version
2023-11-02
JK
