Using I2C OLED Display#
Using I2C on BeagleY-AI is similar to using it on any Raspberry Pi compatible board. The image below shows the BeagleY-AI I2C pinout. For more information check pinout.beagley.ai/pinout/i2c.
Fig. 139 BeagleY-AI I2C pinout#
OLED (ssd1306) displays#
Wiring/connection#
Following the I2C pinout shown above let’s make the connection of our OLED display with BeagleY-AI. Connection for both 128x64 and 128x32 resolution displays are demonstrated in the images below:
OLED display 128x32
Fig. 140 OLED display 128x32#
OLED display 128x64
Fig. 141 OLED display 128x64#
To check if your OLED is correctly connected to your BeagleY-AI you can use i2cdetect command as shown below.
i2cdetect -y -r 1
The above command should show 3c address occupied in the output, which is the default I2C address of our OLED display.
debian@BeagleBone:~$ i2cdetect -y -r 1
    0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:                         -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- 3c -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Using kernel driver#
To use the kernel driver to drive the SSD1306 oled, we have created an overlay /boot/firmware/overlays/k3-am67a-beagley-ai-i2c1-ssd1306.dtbo. To load the overlay you have to add fdtoverlays /overlays/k3-am67a-beagley-ai-i2c1-ssd1306.dtbo to /boot/firmware/extlinux/extlinux.conf as shown below.
Note
Current overlay is created for 128x64 OLED displays, you can update the overlay to use it for other resolution OLED displays.
label microSD (default)
kernel /Image
append console=ttyS2,115200n8 root=/dev/mmcblk1p3 ro rootfstype=ext4 resume=/dev/mmcblk1p2 rootwait net.ifnames=0 quiet
fdtdir /
fdt /ti/k3-am67a-beagley-ai.dtb
After rebooting the board you should see /dev/fb0 available.
debian@BeagleBone:~$ ls /dev | grep fb
fb0
To show random noise on the display you can use /dev/urandom and feed it to /dev/fb0,
cat /dev/urandom > /dev/fb0
Random noise on SSD1306 OLED
Fig. 142 Random noise on SSD1306 OLED#
To show blank screen you can use /dev/zero and feed it to /dev/fb0,
cat /dev/zero > /dev/fb0
Blank (black/zero) SSD1306 OLED pixels
Fig. 143 Blank (black/zero) SSD1306 OLED pixels#
To fill the screen with white pixels you can create a python script called fill-oled.py to create data.out file and feed it to /dev/fb0,
nano fill-oled.py
Copy paste the below code to fill-oled.py,
xsize = 128
ysize = 64
with open('data.out', 'wb') as f:
for y in range(0, ysize):
    for x in range(0, xsize):
    pixel = 255
    f.write((pixel).to_bytes(1, byteorder='little'))
To get the data.out from fill-oled.py file execute the command below,
python fill-oled.py
The above command should create a file called data.out. To feed data.out to /dev/fb0 execute the command below,
cat data.out > /dev/fb0
Fill (white/ones) SSD1306 OLED pixels
Fig. 144 Fill (white/ones) SSD1306 OLED pixels#
Using Python with smbus2#
For users who prefer a pure Python approach without kernel drivers, you can use the smbus2 library to directly control the SSD1306 OLED display. This method provides low-level control and works well for custom display logic.
Install smbus2#
First, install the required Python package:
pip install smbus2
Python script for SSD1306#
Create a Python script to control the OLED display. Below is an example that demonstrates basic display initialization and control:
import smbus2 as smbus
_COMMAND_MODE = 0x80
_DATA_MODE = 0x40
_DISPLAY_OFF = 0xAE
_DISPLAY_ON = 0xAF
_INVERSE_DISPLAY = 0xA7
_SET_BRIGHTNESS = 0x81
BasicFont = [[0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00],
             [0x00, 0x00, 0x5F, 0x00, 0x00, 0x00, 0x00, 0x00],
             # ... (additional font data)
class i2c_display:
    def __init__(self, bus_id=1, address=0x3c):
        self.bus = smbus.SMBus(bus_id)
        self.address = address
        self.width = 128
        self.height = 64
        self.pages = self.height // 8
        self.buffer = [0] * (self.width * self.pages)
    def command(self, cmd):
        self.bus.write_byte_data(self.address, _COMMAND_MODE, cmd)
    def data(self, data):
        self.bus.write_byte_data(self.address, _DATA_MODE, data)
    def init_display(self):
        # Display initialization sequence
        self.command(_DISPLAY_OFF)
        self.command(0x20)  # Set memory addressing mode
        self.command(0x00)  # Horizontal addressing mode
        self.command(0xB0)  # Set page start address
        self.command(0xC8)  # Set COM output scan direction
        self.command(0x00)  # Set low column address
        self.command(0x10)  # Set high column address
        self.command(0x40)  # Set start line address
        self.command(0xA1)  # Set segment re-map
        self.command(0xA6)  # Set normal display
        self.command(0xA8)  # Set multiplex ratio
        self.command(0x3F)  # 1/64 duty
        self.command(0xA4)  # Display all on resume
        self.command(0xD3)  # Set display offset
        self.command(0x00)  # No offset
        self.command(0xD5)  # Set display clock divide ratio
        self.command(0x80)  # Default ratio
        self.command(0xD9)  # Set pre-charge period
        self.command(0xF1)
        self.command(0xDA)  # Set com pins hardware configuration
        self.command(0x12)
        self.command(0xDB)  # Set VCOMH deselect level
        self.command(0x40)
        self.command(0x8D)  # Enable charge pump regulator
        self.command(0x14)
        self.command(_DISPLAY_ON)
    def clear(self):
    def show(self):
        # Write buffer to display
        for page in range(self.pages):
            self.command(0xB0 + page)  # Set page address
            self.command(0x00)          # Set lower column address
            self.command(0x10)          # Set higher column address
            for col in range(self.width):
                self.data(self.buffer[page * self.width + col])
# Example usage
display = i2c_display(bus_id=1, address=0x3c)
display.init_display()
display.clear()
display.show()
Note
This is a simplified example. For a complete font rendering system and advanced features, consider using existing Python libraries like luma.oled or Adafruit_SSD1306.
Tip
The smbus2 approach is particularly useful when you need fine-grained control over the display or want to integrate OLED control into existing Python applications without kernel driver dependencies.
Setup ssd1306 linux software#
There are several examples available online to use OLED (ssd1306) displays under linux. We are using ssd1306_linux from armlabs to demonstrate how you can write to an OLED (ssd1306) display.
Tip
For detailed usage examples of the library check Examples section of the Readme.
Note
If you tried Using kernel driver, you must remove the fdtoverlays /overlays/k3-am67a-beagley-ai-i2c1-ssd1306.dtbo line from /boot/firmware/extlinux/extlinux.conf and reboot your BeagleY-AI board before following the instructions provided below.
Clone the ssd1306_linux github repository on your BeagleY-AI.
git clone https://github.com/armlabs/ssd1306_linux.git
Change directory to your cloned ssd1306_linux github repository.
cd ssd1306_linux
Execute make to build the binary to control your I2C OLED display.
make
Now, you should have ssd1306_bin binary file generated in the folder that you can use to easily write text on you I2C OLED (ssd1306) display.
Example1: Hello World!!!!#
let’s create a script inside the repository (ssd1306 folder) to print Hello World!!!! on the screen.
nano hello-world.sh
Now copy paste the code shown below in your hello-world.sh file. Update the code if your display resolution is not 128x64, comment out first line and uncomment second line to choose 128x32 display size.
./ssd1306_bin -n 1 -I 128x64
#./ssd1306_bin -n 1 -I 128x32
./ssd1306_bin -n 1 -c
./ssd1306_bin -n 1 -r 0
./ssd1306_bin -n 1 -x 1 -y 1
./ssd1306_bin -n 1 -l "Hello World!!!!"
Execute the hello-world.sh script using command below,
source hello-world.sh
Executing the command above should print Hello World!!!! on your OLED display.
Hello World!!!! on 128x64 OLED
Fig. 145 Hello World!!!! on 128x64 OLED#
Hello World!!!! on 128x32 OLED
Fig. 146 Hello World!!!! on 128x32 OLED#
Understanding the code#
./ssd1306_bin -n 1 -I 128x64 ①
#./ssd1306_bin -n 1 -I 128x32 ②
./ssd1306_bin -n 1 -c ③
./ssd1306_bin -n 1 -r 0 ④
./ssd1306_bin -n 1 -x 1 -y 1 ⑤
./ssd1306_bin -n 1 -l "Hello World!!!!" ⑥
① Use this command to set OLED display resolution to 128x64
② Use this command to set OLED display resolution to 128x32
③ Clear the display
④ Set rotation to 0/normal
⑤ Set cursor to location x:1 y:1
⑥ Write Hello World!!!! to display as line using -l command.
Note: We are using -n 1 because our OLED display is connected to /dev/i2c-1 port.
Example2: Date and time#
To print the date and time on our OLED screen we will be using date command but you can also use hwclock command to show date and time from onboard RTC. For details on using date and hwclock you can check Using the on-board Real Time Clock (RTC) demo.
Let’s create date-time.sh in the same folder.
nano date-time.sh
Now copy paste the code shown below in your date-time.sh file. Make sure to update the code if your display resolution is not 128x64, comment out first line and uncomment second line to choose 128x32 display size.
while :
do
./ssd1306_bin -n 1 -f 1 -m "$(date +%Y:%m:%d)\n\n$(date +%H:%M:%S)"
done
Execute the date-time.sh script using command below,
source date-time.sh
Executing the command above should print Date & Time on your OLED display.
Date & Time on 128x64 OLED
Fig. 147 Date & Time on 128x64 OLED#
Date & Time on 128x32 OLED
Fig. 148 Date & Time on 128x32 OLED#
while : ⑤
do
./ssd1306_bin -n 1 -x 1 -y 1 ⑥
./ssd1306_bin -n 1 -f 1 -m "$(date +%Y:%m:%d)\n\n$(date +%H:%M:%S)" ⑦
sleep 0.2 ⑧
done
③ Clear the display
⑤ Run infinite loop to regularly update screen.
⑥ Set cursor to location x:1 y:1
⑦ Write Date and Time to display on separate lines as message using -m command.
⑧ Sleep for 200ms (200 milli seconds)
Tip
Other I2C devices can also be connected and used with BeagleY-AI in the same way shown in this demo.
