Using IMX219 CSI Cameras#
Camera connection#
You have to make sure the CSI camera FPC cable is connected in proper orientation for camera to work properly. The image below shows how it should look when connected correctly.
Tip
The image shows camera connection to CSI0
port, you can similarly connect a camera to CSI1/DSI0
port
Fig. 151 BeagleY-AI camera connection#
Configuring CSI camera#
To enable an IMX219 CSI camera, we have to modify the following file: /boot/firmware/extlinux/extlinux.conf
. We can check the available list of Device Tree Overlays using command below,
ls /boot/firmware/overlays/ | grep "beagley"
When executed the above command should give output show below,
debian@BeagleBone:~$ ls /boot/firmware/overlays/ | grep "beagley"
k3-am67a-beagley-ai-csi0-imx219.dtbo
k3-am67a-beagley-ai-csi0-ov5640.dtbo
k3-am67a-beagley-ai-csi1-imx219.dtbo
k3-am67a-beagley-ai-dsi-rpi-7inch-panel.dtbo
k3-am67a-beagley-ai-lincolntech-185lcd-panel.dtbo
Using CSI Port 0#
Add the line shown below to /boot/firmware/extlinux/extlinux.conf
file to load the IMX219 CSI0 device tree overlay:
fdtoverlays /overlays/k3-am67a-beagley-ai-csi0-imx219.dtbo
Your /boot/firmware/extlinux/extlinux.conf
file should look something like this:
label microSD (default)
kernel /Image
append console=ttyS2,115200n8 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait net.ifnames=0
fdtdir /
fdt /ti/k3-am67a-beagley-ai.dtb
initrd /initrd.img
Now reboot you BeagleY-AI to load the overlay,
sudo reboot
After reboot
you can use beagle-camera-setup
to setup your IMX219 CSI camera,
sudo beagle-camera-setup
beagle-camera-setup
should give you below output,
debian@beagle:~$ sudo beagle-camera-setup
[sudo] password for beagle:
IMX219 Camera 0 detected
device = /dev/video-imx219-cam0
name = imx219
format = [fmt:SRGGB8_1X8/1920x1080]
subdev_id = /dev/v4l-imx219-subdev0
isp_required = yes
To check if the configuration is successfull you can check the video devices
with ls /dev/ | grep video
and you should see video-imx219-cam0
listed as show below,
beagle@beagle:~$ ls /dev/ | grep video
video-imx219-cam0
video0
video1
video2
video3
video4
video5
video6
video7
video8
Using CSI Port 1#
Photos & video#
Troubleshooting#
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
beagley-ai microSD (extlinux.conf)
1: microSD Recovery
2: microSD (RPI 7inch panel)
3: microSD (lincolntech-185lcd panel)
4: microSD (csi0 imx219)
5: microSD (csi1 imx219)
6: microSD (csi0 ov5640)
7: microSD (default)
Enter choice: 4
